Reply To: PolyBook 2020 – blanchsb
Forum Archive PolyBook 2020 – blanchsb Reply To: PolyBook 2020 – blanchsb
#50436
Shawn Blanch
    August 24, 2019 – Day 4: Modeling Revolver – Adding Details: Handle
    Wow! The hande extrusion section was a lot more rough for me than the tutorial. Somehow I ended up with a couple extra faces on the lower strap extrusion and it took a decent amount of work to flatten it even with the Loop Tools Add-On. But I am glad I had it handy or it would have been worse and I would have started the handle exercise all over again.
    The screws taught me that sometimes it is better to extrude some faces as opposed to ‘cutting’ other faces back. Extruding the outer flat-head round part to make the flat-head slot was much easier than cutting the flat-head slot, mainly because I had already made the screw head somewhat rounded so cutting faces back proved to be troublesome. The tutorial training saved the day there.
    New shortcut keys learned today as well: F9 (context menu for last action), and Ctrl + Spacebare for toggle full screen. Huzzah! Also I kinda like seeing one side in edit mode and the other in object mode.
