Reply To: Playblast is overwriting previously rendered files… ๐Ÿ™ˆ๐Ÿ˜ญ
Forum Archive Playblast is overwriting previously rendered files… ๐Ÿ™ˆ๐Ÿ˜ญ Reply To: Playblast is overwriting previously rendered files… ๐Ÿ™ˆ๐Ÿ˜ญ
#99768
    Maybe you can take advantage of the file output node? I remember in this old tutorial, the teacher uses it to get around a similar issue if I remember correctly. You can check it out:
    https://cgcookie.com/lessons/pre-compositing
