Reply To: Pattern not showing in Blender 2.8
Forum Archive Pattern not showing in Blender 2.8 Reply To: Pattern not showing in Blender 2.8
#28637
Thibaut Bourbon
    Hi @garethgr  , your node setup is looking good so far 🙂
    If you didn’t scale the plane up in the edit mode, select it, hit Ctrl+A and apply the scale. Alternatively, you can also change the X,Y and Z scale of your mapping node. The plane you’re using seems to be smaller than the spacing so hopefully this will fix your issue, let me know!
    /Thibaut.
