Reply To: One of the first steps to the video is to tab into edit mode / open the uv editor. When I opened the project file provided…
Forum Archive One of the first steps to the video is to tab into edit mode / open the uv editor. When I opened the project file provided… Reply To: One of the first steps to the video is to tab into edit mode / open the uv editor. When I opened the project file provided…
#22442
Nick Bell
    Thank you for the help!
    I had hit a key to select. It had the object highlighted still wouldn’t let me switch to edit mode. I De-selected and re-selected the object and then I was able to change to edit mode.
    Where hitting a because it is a “select all” option. Does that stop you from changing to a different mode?
