@dostovel I [finally] got around to testing your scene. You’ve set it up great! Only thing I had to do was edit the output file path to be relative. Your instructions are great btw!
As one last test, can you open each of your .blends and check that the output file path starts with: //Render Output/…
If that renders as expected to the proper directory, that means your .blends are ready for anyone to open and start rendering! I will update the original thread with instructions.
PS: I just realized that 2.7x requires CUDA installed for GPU and my linux OS isn’t supported (debian 9 stretch). So I can’t render these scenes with GPU and CPU is taking over an hour per frame. HOWEVER I can enable CUDA jut fine on 2.8 without having the cuda toolkit installed (?! Not sure how that’s possible). So if you want to update your scenes to render in 2.8, I could render faster with GPU. Not required or anything, just an option.
