@theluthier I did a couple of things:
– The file with the Z pass and Vector Pass enabled to make the motion blur in compositing was 50MB to 60MB, the file with no passes enabled but motion blur by default was 15MB. Render times were not that much different. So I opted to make both files with no passes enabled whatsoever so they were 15MB and that way Google Drive space will be enough but most importantly it’ll probably help with the file duplicating since it will be easier to upload and sync 15MB files then 60MB files.
– Samples are at 256. I’ve never done renders with samples so low but it seems to work fine.
– Eliminated the tiled texture on the background and kept details on the floor.
– Made the background darker since the Heli and the background were the same shade of gray and there wasn’t enough contrast for the Heli to stand out.
– If you agree with the changes and give the green light, then Code Green is a go.
