Reply To: Omar Domenech’s Demo Reel
Forum Archive Omar Domenech’s Demo Reel Reply To: Omar Domenech’s Demo Reel
#46742
    @theluthier Do you think I should keep it under a minute? As it is now it will probably go to 1 minute 30 seconds long. Is it too much? should I cut down time and therefor render time?
    Every EXR is about 25MB if I keep a scene below 600 frames, 15GB of Google Drive should do. It’ll be a matter of uploading Scene 1 to Google Drive, render it, copy paste rendered files to my local hard drive, delete from drive, upload scene 2, repeat again and again for what it’ll be at least 10 scenes.  😰
    Sometimes I don’t understand Blender’s file path. Sometimes the path breaks, sometimes it doesn’t, sometimes you pack a texture into the .blend, sometimes it goes missing. Sometimes the library path holds up, sometimes you open the file and the path is broken. Sometimes you do it on a PC and it works, sometimes you make the path on a Mac and the path gets set up differently.
    Blender needs an asset manager ASAP.
