@dostovel I’m sure that how the Elders of CGC do it yes 🙂
Would be great if the placeholder system be improved, a simple text file with the list of rendered frame would be lighter to sync and appending it would be not so hard to do either. Then with drive or dropbox we could skip syncing the rendered images and start directly with the blend file and the text file contaiing the list of rendered (and being rendered) output. Maybe the blender developer should consider it, I’ll check that 🤔
I just want to make sure, you render with 500 samples, is that correct ? I followed the instructions and didn’t change anything in the blend file, but I read earlier in the thread something mentionning 1500 samples, can’t find it anymore.
