Reply To: MTL Files Missing Color Info When Imported To Unity (INFO)[RESOLVED]
Forum Archive MTL Files Missing Color Info When Imported To Unity (INFO)[RESOLVED] Reply To: MTL Files Missing Color Info When Imported To Unity (INFO)[RESOLVED]
#38759
Jonathan Gonzalez
    @paulhaynes1955 Glad to hear it. I personally rarely if ever use OBJ files. I almost always use FBX files, so I would recommend using that file format instead. Gives you everything you’d get with an OBJ file but it also allows you to keep separate hierarchies within the mesh and also creates the materials properly. If you use animations you can export out an FBX file that contains all that included as well.
