Reply To: MTL Files Missing Color Info When Imported To Unity (INFO)[RESOLVED]
Forum Archive MTL Files Missing Color Info When Imported To Unity (INFO)[RESOLVED] Reply To: MTL Files Missing Color Info When Imported To Unity (INFO)[RESOLVED]
#38757
Paul Haynes
    @jgonzalez That’s interesting that you get the color. Every single material that I create has the same codes in the MTL file as the one that I listed above. Apparently, there are others having the same problem because I’ve seen comments in multiple locations referencing the colors not showing up.  Several youTube videos that I watched also did not show the color. Maybe there are some magic settings that I (and the others) are not using? I’ll look into it further but I do have other things to do and the workaround in my video allows me to apply the colors, so I won’t be spending a lot of time on it. Thanks for the response.
    Any chance you can cut and paste your mtl file so I can see what it looks like?
    Edit: Are you using the B2U add-on?
