Reply To: Mirrored linked objects flip in Edit mode vs Object mode
Forum Archive Mirrored linked objects flip in Edit mode vs Object mode Reply To: Mirrored linked objects flip in Edit mode vs Object mode
#49274
amazinglarry4tw
    Hey @spikeyxxx thanks for the reply!  One mistake I was making was the Single User — I was doing a search for Unlink Connection (which obviously wasn’t working).
    However, I’m still running into the same issue.  I selected all the front planks and made them single user, selecting Object & Object Data.  Selected the front planks and applied rotation, linked them (and they all reverted to the same rotation).  I applied a mirror modifier to the linked planks and applied the modifier link.
    Then as soon as I start rotating any of the front planks on the X or Z axis and go into edit mode, the same behavior crops up.  Here are some screenshot showing the steps:
    Unlinked (Single Users) and applying the rotation transform
    Linking Object data (rotations clear)
    Linking Object Data and applying a mirror modifier to the top plank
    Applying Modifier Link
    Rotating the bottom plank 180 degrees on the X axis
    With the bottom plank still selected, pressing Tab to enter Edit mode
