Reply To: Messy green areas in normal map
Forum Archive Messy green areas in normal map Reply To: Messy green areas in normal map
#26078
Jonathan Lampel
    In both of the files the lowpoly was also set as the cage, so I cleared out that setting (which will use a default extrusion cage behind the scenes), and then lowered the extrusion so that it’s not so massive. 1 unit is really far away, so that might be what was giving you trouble.
