Hi @nathitappan ,
You can make the Mask darker, by changing the Overlay to 1:
And the effect of the Smooth Brush depends on the Mesh Density, as well as on the Brush Strength. Also, if you use the SHIFT shortcut, the Smoothing uses the Strength of the Brush you are using at that moment, not the Strength of the Smooth Brush.
