Reply To: Making Quads on beveled corners
Forum Archive Making Quads on beveled corners Reply To: Making Quads on beveled corners
#98455
    If it’s in the flat part, then it’s ok. You can re-arrange the topology so your edges reach the flat part with quads and then you bite and close with a triangle in where is flat. You can have Ngons and triangles in flat areas without an issue.
