Reply To: Making a grid mesh object (A plane with a grid of circular holes in it)
Forum Archive Making a grid mesh object (A plane with a grid of circular holes in it) Reply To: Making a grid mesh object (A plane with a grid of circular holes in it)
#85843
    They way you have it’s fine, using an array. You just need one hole modeled and if you want to resize it it’s fairly simple to select the loops and scale the circle up or down. That’s the way I would do it, no fancy or complicated setup, straight good old poly modeling.
