Reply To: Long Inquiry About the front curve of the revolver !
Forum Archive Long Inquiry About the front curve of the revolver ! Reply To: Long Inquiry About the front curve of the revolver !
#29054
Jonathan Lampel
    @boulagab I would try to not use multi-resolution for this one. Sculpting is a perfectly good method that is used by a lot of companies, but if you’re going to do it then you’ll need to do it for the whole gun and not just this one part of this one piece. It’s a simple enough problem that it’s not worth all that heavy geometry which will make the rest of the modeling more difficult. Hope that helps!
