Reply To: Linked Object and Material Data
Forum Archive Linked Object and Material Data Reply To: Linked Object and Material Data
#94270
Dwayne Savage
    Another option is to use the objects pass index(Object tab of properties editor under Relations panel). Then you can use that number to select which image the material displays. Both 0 and 1 show the same image in the following. Also any number higher than the last one will show the last image.
