Reply To: “Large Bump” Musgrave: range needs to be remapped?
Forum Archive “Large Bump” Musgrave: range needs to be remapped? Reply To: “Large Bump” Musgrave: range needs to be remapped?
#75481
    There is another way; as a lot of Nodes from the Shader Editor are available in GN, you could already use the Spreadsheet to get the exact Values:
    (This is 3.4, in 3.3  the result from the Viewer Node is not yet visible in the 3D View, but the spreadsheet is the same.)
