Reply To: Keeping clamp override on the non-vertex bevel yields different results than in the tutorial
Forum Archive Keeping clamp override on the non-vertex bevel yields different results than in the tutorial Reply To: Keeping clamp override on the non-vertex bevel yields different results than in the tutorial
#92931
Philipp Schulte
    I had the same Problem. When you do the duplication while doing the selection with the faces “3” instead of edges”1″, it duplicates many edges and the whole thing doesnt work. You need to select the faces via wireframe and the “1”, then it should work just fine. Made a 30 minutes tutorial into a 1,5 hour tutorial.
