Forum Archive › It is just turns pink ! › Reply To: It is just turns pink !
Hi shanr, you are using a Mix Shader instead of a Color > Mix RGB Node! (You can see a red line where you connect the output of the Mix Shader to the Color input of the Background Shader, indicating that the connection is wrong!)
