Reply To: Issue with AO baking, any clues?
Forum Archive Issue with AO baking, any clues? Reply To: Issue with AO baking, any clues?
#83778
    HI Anton,
    You can Join several Objects together by Selecting them and then CTRL+J.
    If you have several houses unwrapped, you can Select them all in the UV Editor and go to UV > Pack Islands.
    You can also Unwrap several Objects at once, by Selecting them all and then go into Edit Mode and Unwrap…that way Islands shouldn’t overlap, but you can always run Pack Islands to be sure..
