Reply To: Is this type of overlaping mesh a problem?
Forum Archive Is this type of overlaping mesh a problem? Reply To: Is this type of overlaping mesh a problem?
#99209
Deb kanta Guin
    Okay Martin, thank you very much. I really need to clear a few things up now. Here’s what’s happening:
    First, I wasn’t able to model this as a single mesh because it was creating a 6-edge pole in a very tight area also baveling things was messy026-01-18 131653.png026-01-18 131707.png
    and I couldn’t figure out how to resolve it properly. That’s why I ended up creating two separate meshes.026-01-18 132020.png
    Because of that—and probably due to some incorrect vertex placement—I’m now facing alignment issues between the parts.
    As you can see here, I’m using this as a completely static object, only as a decorative element.
    026-01-18 130842.pngPlease let me know what I should do now.
    Do I need to fix anything at this stage?
    And if yes, how should I fix it without introducing bad practices?
