Reply To: Inset for cartridge opening is splitting into two areas instead of one.
Forum Archive Inset for cartridge opening is splitting into two areas instead of one. Reply To: Inset for cartridge opening is splitting into two areas instead of one.
#93353
    ‘Double Vertices” are indeed the most likely cause.
    When you want to Merge ‘double Vertices’, you need to make sure that all are Selected.;use A to Select all, or switch to Wireframe Mode and then you can use Box Select (or Circle or Lasso Select).
