Hey @adrian-h,
Your image is not showing above, can you post it again below as a reply.
It is probably what @spikeyxxx said, double verts. In edit mode for the object in question, press ‘A’ to select everything then press ‘M’ and select ‘By Distance’ to remove any double verts.
