In order to protect the grainy sun surface from beeing “erased” at both ends of the sun flare I had to switch the “Blende Mode” for the sun flare material from “Alpha Blend” to “Alpha Hashed” and crank up the number of samples significantly in order to approximate to the look of “Alpha Blend”:
1) Alpha Blend:
2) Alpha Hashed:
