Forum Archive › I'm trying to do the UV consolidation and transfer the UV map back to the original object. The transfer fails due to a dif… › Reply To: I'm trying to do the UV consolidation and transfer the UV map back to the original object. The transfer fails due to a dif…
Solution found: I had “limit selection to visible” switched on when separating the meshes of the unified UV map. Switching it of separated the whole objects…
