Forum Archive › I’m having a hard time cutting the grooves on the corners. I feel like there’s a more precise way to do it than knife the 4 corners, but struggle with subdivide. Is there a better approach than knife? › Reply To: I’m having a hard time cutting the grooves on the corners. I feel like there’s a more precise way to do it than knife the 4 corners, but struggle with subdivide. Is there a better approach than knife?
A small addition to the solution from Jonathan: use Select Mirror to quickly select the similar faces.
P.S. I used the Pie Menu addon for the Pie menus. It can be enabled here: Edit->User Preferences->Add-ons->Pie Menu
