I tried at first to use the newer system, but couldn’t figure out how to get the mapping controls like Kent used to work with it and it was a bit of a workaround to even get it started. So I switched to the particle system for the Vellus, and I may go back and do it for the eyebrows. The lashes were a small enough area it wasn’t too much trouble to do things a bit more manually. I think the newer system will be fine for the scalp hair later though (as it has the ability to do some things that the particle system couldn’t do as easily). The vellus really does add just a little bit to it.
At one point, though… I messed up the scale and… it didn’t quite turn out right… 😀 (I had the diameter scale too high… I had it set to .01 instead of .001 😀 )
