Reply To: I WILL make it through the HUMAN course!
Forum Archive I WILL make it through the HUMAN course! Reply To: I WILL make it through the HUMAN course!
#100598
Grady Pruitt
    Not sure if how much of it is touching up the skin painting and how much of it is “reworking” the material, but for once, I’m feeling happy with how the skin is looking in different lighting. Eyebrows need work and not sure what’s causing the “pale” under the brow. Still need to finish the Zones of the Face and blemishes. I’ll probably touch on the eyebrows while working the hair. But coming along! (Overall, it feels less “pink” than my references, but doesn’t feel like “makeup” now.)
    @spikeyxxx — turns out I did have the solidify turned off for render. I moved the particles back below it, and it rendered fine… so not sure what was going on earlier. Also, did rotate the UVs back to vertical and increased the scale value from the mapping node I was using for that.
