Forum Archive › I setup the material with the Metal files (Base Color, Metallic, Bump and Normal) but the Totem doesn’t show them whereas the other objects do, What’s wrong? › Reply To: I setup the material with the Metal files (Base Color, Metallic, Bump and Normal) but the Totem doesn’t show them whereas the other objects do, What’s wrong?
You may also want to check the UVs – perhaps the UV map got deleted somehow? If you try again with the original source file it should work.
