Reply To: I setup the material with the Metal files (Base Color, Metallic, Bump and Normal) but the Totem doesn’t show them whereas the other objects do, What’s wrong?
Forum Archive I setup the material with the Metal files (Base Color, Metallic, Bump and Normal) but the Totem doesn’t show them whereas the other objects do, What’s wrong? Reply To: I setup the material with the Metal files (Base Color, Metallic, Bump and Normal) but the Totem doesn’t show them whereas the other objects do, What’s wrong?
#70468
    @squidring I cannot see what you are doing wrong; your connections seem to be correct:
    Are you sure that that is your Totem Material in your screenshot?
