Reply To: I see no option to Apply Modifier for the Rivet’s template cube.
Forum Archive I see no option to Apply Modifier for the Rivet’s template cube. Reply To: I see no option to Apply Modifier for the Rivet’s template cube.
#75768
    Yeah it’s ok, that’s just how Blender previews a modifier. It looks like a cube on the outside because that is your underlying or original geometry, and it shows the circle inside as the result of your modifier over the cube. That all happens when you go into Edit Mode, but you can change that using this button, which will turn off the edit mode preview of the modifier:
