Hi Ulf @supertuffe ,
You could render with your CPU (like Kenan does in the Tutorial); with 296 Samples, that shouldn’t take forever.
When you render 1 Frame, you can have a look at the peak Memory usage and see if it is a lot more than the 6Gb…maybe it is worth trying to optimize the scene, if you really want to use the GPU.
You can save Memory almost anywhere. Geometry Nodes wouldn’t be the first place I would look though. I still have to watch the Course, to see what the ‘best’ ways are to save Memory, but I’d first try the CPU.
