Reply To: I can't seem to change the 'ball type' in the UI panel – all I can do is hide the different types in the ouliner which is …
Forum Archive I can't seem to change the 'ball type' in the UI panel – all I can do is hide the different types in the ouliner which is … Reply To: I can't seem to change the 'ball type' in the UI panel – all I can do is hide the different types in the ouliner which is …
#24534
David Frazier
    Neither can I change the “ball type” sin the UI Panel. Plus whenever I select 1 of the 4 tans (Root, Body, Squash, Spin) the UI flies all over the place , AND does NOT even select its respective counterpart (If a click “Squash” it highlights in the tab but does nothing to the squash controls in the viewport. This exercise is quite glitchy, so much so that I can’t continue until fixed. Using 2.77
