Reply To: I can’t see the Mesh Projected Mask
Forum Archive I can’t see the Mesh Projected Mask Reply To: I can’t see the Mesh Projected Mask
#97758
Chunck Trafagander
    Hey there,
    So if you change the “Projection Mode” under the “Layer Projection” header to “Decal”, and then try to change the Image that the mask is using, are you able to notice any difference on your model?
