Reply To: I can not key everything with I key at the first passing pose. It returns an error “Keing set failed to insert any keyframes”. How can I solve it? Thanks
Forum Archive I can not key everything with I key at the first passing pose. It returns an error “Keing set failed to insert any keyframes”. How can I solve it? Thanks Reply To: I can not key everything with I key at the first passing pose. It returns an error “Keing set failed to insert any keyframes”. How can I solve it? Thanks
#27270
Wayne Dixon
    You need to set what keyframes you want first before using the ‘available’ keying set.
    Otherwise, Blender will not know what to actually key.
