Reply To: I am having trouble closing the window (the hidden one) that can be closed using the "end" key. Because I am using Windows…
Forum Archive I am having trouble closing the window (the hidden one) that can be closed using the "end" key. Because I am using Windows… Reply To: I am having trouble closing the window (the hidden one) that can be closed using the "end" key. Because I am using Windows…
#21803
Phoebe Cunningham
    No, I think he means he is working on a Macbook and to close and open Tools you use ‘T’, however to close and open the right hand Transform Tools, on a Windows you use ‘End’ but what is the key for this on a Macbook? (I’m having the same problem)
