I think your question is answered by the lecture “building up values. Make sure you add layers above your plain surface and add a clipping mask to each layer. This will prevent your values to be displayed outside the original form. Furthermore you should work with a big soft brush. Enable the the Transfer setting to Pressure sensitive and ensure that brush size is Not beeing affected by pen pressure. I hope it solves your problem. Have fun.
