Reply To: How would I create two stripes on the column, one top and one bottom?
Forum Archive How would I create two stripes on the column, one top and one bottom? Reply To: How would I create two stripes on the column, one top and one bottom?
#87075
Adrian Bellworthy
    You have a roughness value in the top BSDF, for the concrete, which is mixed with the stripe in the first mix, then its mixing again with the second BSDF.
    This is what is causing the roughness mix up.
    Three BSDF’s or a color ramp with three flags for stripe / concrete / stripe into one mix as the factor.
