Reply To: How to set correctly Texture Paint Opacity?
Forum Archive How to set correctly Texture Paint Opacity? Reply To: How to set correctly Texture Paint Opacity?
#29475
    Any time you see that bright pink color in Blender it means a texture is trying to be sourced erroneously. So that has to mean your metal rim object doesn’t have either A) the material applied or B) there’s no texture plugged into the material that is applied.
    Once your texture is applied and no more pink the opacity slider should function as expected.
