Reply To: How to match arm position & rotation when Switching from FK to IK for the arm?
Forum Archive How to match arm position & rotation when Switching from FK to IK for the arm? Reply To: How to match arm position & rotation when Switching from FK to IK for the arm?
#56387
Wayne Dixon
    Hi Judisak,  I don’t have any tricks to matching when switching.  I didn’t build snapping into the rigs.  But here’s some advice for doing it by eye.
    -Make sure you key both the IK and FK on the switch.
    -switch over 1 frame (key both IK and FK on both frames as mentioned above)
    -try to avoid switching at all and stick with either IK or FK on that body part for the entire shot (probably not possible in this circumstance)
    -try to switch during a move so it is easy to flip the frames and match the motion – OR
    -try to switch when it is perfect still, so when you flip the frames you can see when it isn’t matching and tweak it easily.
    (The last 2 tips depend on the situation.  1 way is usually easier in different shots)
    Hope that helps.
