Reply To: How to fix the particles bugs?
Forum Archive How to fix the particles bugs? Reply To: How to fix the particles bugs?
#78572
Adrian Bellworthy
    Houston, we have a problem!
    You say it only happens in the render, not in the viewport?
    Did you adjust any settings, like the velocity, before rendering?
    The viewport particle animation is cached to memory, to speed up the viewport play back.
    If you changed anything without re-caching there will be differences.
    Its hard to determine what the exact cause is from a video, if you can share the .blend file we can take a look and diagnose the issue.
    My first guess is the velocity, did you set keyframes on the velocity setting?
    It could also be a GPU issue, make sure your GPU drivers are up to date.
    You can share the .blend file with Google Drive or Dropbox or similar and post the link here.
