Reply To: How do i access the gizmo texture file?
Forum Archive How do i access the gizmo texture file? Reply To: How do i access the gizmo texture file?
#26201
    @mtmorrow – The gizmo’s textures are “packed” into the .blend file, meaning they’re included. So when you go to add the texture it’s simply available in the drop-down instead of importing the texture file externally.
    Can you confirm that the gizmo textures are available in the texture select list of the image texture node?
