Forum Archive › Hi, when trying to create the skin modifier I keep getting an error that says "No valid root vertex found (you need one pe… › Reply To: Hi, when trying to create the skin modifier I keep getting an error that says "No valid root vertex found (you need one pe…
Okay – working again – per birkov above, once you extrude your first point the warning goes away. I had trouble even extruding until I realized I needed to be in “vertex select” in edit mode.
