Reply To: Hi, What key do you use to set the offset value at 03.09? When I press "I" it just gives time the insert key frame menu,
Forum Archive Hi, What key do you use to set the offset value at 03.09? When I press "I" it just gives time the insert key frame menu, Reply To: Hi, What key do you use to set the offset value at 03.09? When I press "I" it just gives time the insert key frame menu,
#23735
Hardus Jonker
    Whoops I meant at 01:36
