Reply To: Help, when I try to apply the boolean it breaks
Forum Archive Help, when I try to apply the boolean it breaks Reply To: Help, when I try to apply the boolean it breaks
#99511
    Hi Jesse @AstroHammer101 ,
    The Bevel Modifier needs to be before the Boolean, because the Boolean creates more Geometry, that then (partially) may get Beveled as well (when the Boolean Modifier comes before the Bevel).
    Like I said, the easiest thing is, to not Apply any Modifier. And not change the order. It’s fine as it is.
    I can’t remember why you’d want to change anything; I’d have to re-watch this Lesson. If it’s because of the Material, you can just change the Material of the Letters.
