Reply To: HELP problem when merging a cylinder with a cube “Industrial Environments with Eevee”
Forum Archive HELP problem when merging a cylinder with a cube “Industrial Environments with Eevee” Reply To: HELP problem when merging a cylinder with a cube “Industrial Environments with Eevee”
#68818
Adrian Bellworthy
    Hey @sketchmore ,
    after snapping the cylinder to the cube, you need to delete the top face of the cylinder and the bottom face of the cube,
    then connect a vert on the cube to one closest on the cylinder, then again for another vert.
     then you can fill the faces.
