Reply To: hello =) I don’t know why the Bevel modifier (9:20) doesn’t work when I apply it
Forum Archive hello =) I don’t know why the Bevel modifier (9:20) doesn’t work when I apply it Reply To: hello =) I don’t know why the Bevel modifier (9:20) doesn’t work when I apply it
#95258
    Hi Rachid @gecko ,
    Could be a few things. The first thing to do, is to get rid of possible ‘double Vertices’; Select everything (in Edit Mode) with A and then M > Merge > By Distance.
    You should probably also disable the Clamp Overlap, like so:
    And to avoid further problems, make sure the Scale is Applied; in Object Mode: CTRL+A > Apply > Scale.
    Let us know if that helps.
