Reply To: Having an issue with the solidify modifier on the top clamp
Forum Archive Having an issue with the solidify modifier on the top clamp Reply To: Having an issue with the solidify modifier on the top clamp
#69080
    Almost always Apply the Scale,  it is usually better to not Apply the Rotation (and try to always rotate in Object Mode), although it is not crucial. But almost never Apply the Location; that can often get you in real trouble!
    (Those two uses of ‘almost’ are only there to cover possible cases that I haven’t encountered yet, but that maybe exist, where it is better to not Apply the Scale, for instance…)
