Reply To: Ground plane will not fill my scene/footage.
Forum Archive Ground plane will not fill my scene/footage. Reply To: Ground plane will not fill my scene/footage.
#53149
    @originalcharacter The Clip Start and Clip End are there for a reason. If you set the clipping range too large, you get artefacts!
    Here is what happens if you try to set the Clip Start to 0:
    This is an OpenGL thing (also DirectX suffers from this), so your renders won’t be affected by it.
    Same thing with the Camera Clipping:
